2 months later same issue....
Status: Closed · Asked by nooshy1234 on · 0 views
nooshy1234 — Question ·
I have pabbly sending my linkedin connections to my zoho crm but the job titles are not uploading and this is very important information that needs to be transferred over, other what is the point of me usining pabbly an paying for it when im inputting the data by hand? Fix this asap or im leaving a bad review and canceling.
Hey @nooshy1234
Please check carefully your trigger response in the history section of your workflow, you will see the data label which you have mapped in the action step doesn't contain anything only null into it.
Instead of that the occupation which you are receiving from the triggering application, it looks like the name fields are having occupation titles on them.
So, please check the incoming data from the application from where you getting the data and correct the mapped data.
Further, we have checked the action event at our end and it is passing the designation correctly.
