24 hour work flow does not run
Status: Open · Asked by Dove InnerCity Notary on · 0 views
Dove InnerCity Notary — Question ·
I built a flow to respond to new reviews on my Google business account. It works when I run it manually. Per Pabbly it should run automatically when I have new reviews. It has been 3 days and no response to my reviews. The flow is turned on. What is the issue?
Gunjan — Reply ·
Have you been able to check the Task history?
Gunjan — Reply ·
Also, share more details like the workflow URL so the team can check it and help you with it.
Dove InnerCity Notary — Reply ·
Hi, I have 4 new reviews. The workflow has not run. Here is my Google Business Profile link with the reviews, and attached are screenshots of Pabbly. The one that was executed this morning was done by the Pabbly team manually. It did not trigger automatically.
https://www.google.com/search?q=Dove+InnerCity+Notary&rlz=1C1ONGR_enUS1020US1029&oq=dove&gs_lcrp=EgZjaHJvbWUqBggAEEUYQTIGCAAQRRhBMgYIARBFGDkyBggCEEUYQTIGCAMQRRg8MgYIBBBFGDwyBggFEEUYPTIGCAYQRRhBMgYIBxBFGDzSAQc5MzRqMGo5qAIAsAIB&sourceid=chrome&ie=UTF-8&lqi=ChVEb3ZlIElubmVyQ2l0eSBOb3RhcnlI4o6O3_a2gIAIWiMQABABEAIYABgBGAIiFWRvdmUgaW5uZXJjaXR5IG5vdGFyeXoNV2luc3Rvbi1TYWxlbZIBDW5vdGFyeV9wdWJsaWOqAXUKDS9nLzExdmt6MXI2eG0KCy9tLzAxMTZyMmIwEAEqGSIVZG92ZSBpbm5lcmNpdHkgbm90YXJ5KAAyHxABIhuywU3YWtMAX_e5EFtvoi9vtofUccor7APt6HAyGRACIhVkb3ZlIGlubmVyY2l0eSBub3RhcnngAQA#rlimm=2938128895092704490
Your concern will be address on Ticket ID: #138502.
Any updates???
Hello @Joyleak1,
Our team has responded to this query via email. Please check your inbox for a message with Ticket ID: 138502. We hope the information provided there helps resolve your concern.
For any further updates or follow-ups, you may simply reply to that email thread.
