2nd Twilio connection not sending text message.
Status: Closed · Asked by NickJSI on · 0 views
NickJSI — Question ·
I have a connect flow running great with a formatting step and Twilio text message send on new response trigger.
My issue is that I've added a second, follow-up message after a 30 minute delay.
The first text message sends fine, but the secondary one does not send at all.
I duplicated the Twilio action and have been testing it, but nothing seems to work.
Any suggestions?
Hi @NickJSI,
Based on the workflow you have shared, it appears that you have deleted the last two steps of your workflow. Because of this, I am unable to diagnose the exact issue. However, I can see from your Task History that the action step was being executed after the Delay as well.
NickJSI — Reply ·
Thanks Arshil. Apologies for editing after sending. It was a Twilio issue, not Pabbly.
Thank you!
