360 dialog API issue
Status: Open · Asked by Nirvana Entertainment on · 0 views
Hi Team,
I have created new API for 360 dialog, in all my workflows i have used 360 dialog on premise.
But the new API & weblink is showing following error.
webhook url is https://waba-v2.360dialog.io
The new API is on cloud.
When i select 260dialog on cloud for sending template message, not able to send message.
getting following error.
Kindly help me asap.
Hello @nirvana306,
Could you please provide us with the Workflow URL where you are facing this issue This will help us investigate the problem more effectively and assist you accordingly.
link to the workflow
You have my permission to log into my Pabbly Connect account and edit the workflow, if required. Here is the registered email address associated with it.
Hello @nirvana306,
We have made some slight changes to the 360 Dialog (Cloud): Send Template Message action( turned off all the map buttons and changed the language code from en_US to en) and the action now seems to be working fine.
Thanks a lot, issue resolved.
Hello @nirvana306,
As your issue has been resolved, we’d appreciate it if you could share quick feedback on the support received - https://forms.gle/GAjS4wdPYKuhnEYV9
Thank you for your time.
