Acuity Scheduling Tagging for Keap
Status: Open · Asked by Career ACTivate Support on · 0 views
Hello!
Is the Acuity Scheduling Tag to Keap function customizable or only global?
I want Acuity Scheduling to Tag contacts in Keap based on specific appointment type.
For Example:
If someone schedules a consultation with Mike, I want them tagged in Keap as "Consult Scheduled with Mike."
But, if they have ongoing Coaching appointments with Chris, I want the "Ongoing Coaching with Chris" tag applied.
The way my workflow looks, it appears that I can only add a tag globally - for any appointment type scheduled - and not for a specific appointment type.
IS there a workaround? Thanks!
Hi @Career ACTivate,
Could you please provide further elaboration on your use case by recording a short video? Additionally, kindly share the workflow within which you have implemented this use case.
Hi @Career ACTivate,Could you please provide further elaboration on your use case by recording a short video? Additionally, kindly share the workflow within which you have implemented this use case.
Hi, Arshil.
I'm not able to create a workflow because the functionality I need is unavailable in PabblyConnect. That is why I asked my question. I'm looking for a way to create this workflow with the tools currently available.
This function is currently available in Zapier.
You can try adding a Router to your workflow to apply tags based on the appointment type.
