Acuity With Filter To Sheets
OneLove
I'm trying to add my appointment's Contact Information from Acuity to populate the Google Sheets only if the contact doesn't exist.
I tried multiple ways to configure the filter using the email but can't seem to get it to work. Am I missing something?
Supreme
Hey @OneLove
You should use the "LookupSpreadSheet" action step with the filter action step afterward, which will check the existing user from the Sheet and then you can add the user accordingly.
You can also refer to the following video tutorial on how you can use the LookupSpreadSheet Value action step.
