Acumbamail double optin
Status: Closed · Asked by Dzian on · 0 views
Hi team, there are additional settings to enable double optin and welcome email on acumbamail zapier integration.
Can this be added to pabbly too?
Thanks!
Can this be added to pabbly too?Thanks!
Can you please share full screenshots of those options so that we can check the possibility of the same? You can blur the section which you don't wish to be shown while sharing the screenshots.
That's pretty much all, only 2 option for double optin and welcome email are missing from pabbly
Hey @Dzian
We have added the required fields as per your concern. Kindly try now this at your end and let us know if that works for you.
I hope this might help you out.
Cheers!
