Add a comment or note to automation?
Status: Closed · Asked by Nexify on · 0 views
Is it possible to add a note or description to an automation?
For example, we have an automation that needs input in a certain format. I would be good to be able to add a note or comment to the automation explaining that (for our documentation).
Hey @GroeiGarage
Can you please confirm if you want to include notes or a description along with the workflow name?
If not, kindly provide details on where you would like to add notes or a description so that I can better understand your request. It would be helpful if you could share a screenshot to illustrate an example.
No preference, just anywhere.
In that case, you can name the workflow in a way that clearly represents its purpose.
If you wish, you can also create a separate folder specifically for that workflow.
That is not what I mean. I would like a place where I can elaborate a bit more about the purpose of the automation. And what the input format should be.
At the moment, the note feature isn't accessible within the workflow. However, we're eager to incorporate it into our automation. Could you kindly make a single submission on this platform to initiate the process?
That would be great. Where do you want me to make the submission?
As a suggestion you can add a text formatter step that just has the text you want to note and call it "Note for Step Below" or something like that!
This has already been requested 2 years ago apparently
We have already included your request in our planned roadmap, and we are committed to implementing it in the near future.
