Add italian prefix
Status: Closed · Asked by dvall71 on · 0 views
dvall71 — Question ·
I have to add a step by putting the prefix +39 in front of the phone number how do I do it?thanks
dvall71 — Reply ·
Here you can map your data dynamically in place of 8238197911.
how do i take a test? should i receive a whatsapp message?
Fagun Shah — Reply ·
how do i take a test should i receive a whatsapp message
You can map the result of Number Formtter step in your send whatsapp message step's mobile number field.
Fagun Shah
- Automation Freelancer
dvall71 — Reply ·
I did test, everything is correct, it arrives, but not when the order arrives in woocommerce
dvall71 — Reply ·
Did you setup webhook for order created in woocommerce?
yes sure, I did
Can you share workflow name so @Pabbly @Supreme Verma team can look into this
Fagun Shah
dvall71 — Reply ·
Can you share workflow name so @Pabbly @Supreme Verma team can look into this?
YES, can you send me an email?
Pabbly — Reply ·
Please provide us the URL of your workflow so that we can assist you better. We have also emailed you to know your Pabbly Account email address
dvall71 — Reply ·
i don t see your email. mine is [email hidden] account dvall71
Hey @dvall71
Thanks for sharing the details with us. We have tested and checked the WooCommerce response but as in response, it is showing some fluctuation in data.
So, could you please re-capture the webhook response of Woocommerce in your workflow?
Moreover, we have tried a similar use case in the cloned workflow "CLONE - [Woocomerce to WhatsApp]" where we have added a filter in between and it is working fine, please do check it out.
dvall71 — Reply ·
Hey @dvall71
ok check and let you know thanks
