Adding multiple shopify products to a draft order
Status: Open · Asked by Michael Jago on · 0 views
chimmy — Question ·
I've got a flow where the customer fills in a google form about the level of membership they want, in three different tiers.
Each tier will have several different gift vouchers as part of a support package.
How do I make this in Pabbly Connect?
Below if I try to add various variants it doesn't work, and I don't want several different draft orders made per order.
(I want 2 $40 vouchers and 2 $20 vouchers, in shopify it's the same product but with pricing variations)
Thanks!
chimmy — Reply ·
Hi @ArshilAhmad ,
I've got the router set up and it's working fine, I just need to add multiple products to the draft order instead of having to make three separate draft orders, each with one product. I can't seem to add multiple variations of the same product in the draft order which is why two are showing.
Thanks!
Please allow me some time to discuss the possibility of this use case with my team. We will get back to you with an update soon.
