Adding tags in GHL via Pabbly Connect without OVERWRITING
Status: Closed · Asked by Chris Moltz on · 0 views
ApexFD3S — Question ·
Consent to Access & Modify: I don't authorize Pabbly Support to log in to my account.
When I add a tag via Pabbly Connect it overwrites all existing tags on the contact and replaces them with just the Pabbly tag. This breaks my workflows.
How can I add a tag via Pabbly Connect without the overwriting occuring?
Fagun Shah — Reply ·
You don't pass the tag in Create/Update action, you just pass other field values and then in the next step use Add Tag of LeadConnector v2 with contact id mapped from above step.
Fagun Shah
- Automation Freelancer
Hey @ApexFD3S,
Could you please provide us with the Workflow URL where you are facing this issue This will help us investigate the problem more effectively and assist you accordingly.
ApexFD3S — Reply ·
Makes sense - thank you!
