Airtable Stuff Not Showing
Status: Open · Asked by Quiet Money Radio on · 0 views
I Was Wondering Why Some Of My Airtable Stuff Not Showing
I'm Trying To See Why All Of Them Is Not Showing ?
Hey @QuietMoneyRadio
Can you please share the workflow URL once in which you have experienced the same so that we can look into it?
Hey @QuietMoneyRadioCan you please share the workflow URL once in which you have experienced the same so that we can look into it?
IjU3NjAwNTZkMDYzMDA0MzI1MjZjIg_3D_3D_pc
The Workflow URL you have shared doesn't appear to be correct. Please share the correct Workflow URL.
https://connect.pabbly.com/workflow/share/XRVVZwVSBWYHTQNpDl0GIVtPVVEBWwI_XUQCEFNcAXkATQZtVhcIYg1BWHoCRQBhAEkFb1UKAWRYTFVRBVNTIFJfVHgAA10nWxZRKlYTCzhdA1V9BWQ#
Kindly select the correct Workflow that you want to enable on Friday.
Hello
My Workflow is Working But It Only Shows The 1st One However It Doesnt Show The Other 2
Have you tried mapping the workflow ID directly in the action step?
No I don’t know how
Please try now by enabling the map button once and then map the workflow ID in the field.
