Airtable Stuff Not Showing
Status: Closed · Asked by Quiet Money Radio on · 0 views
QuietMoneyRadio — Question ·
Task History ID: IjU3NjAwNTZkMDYzMDA0MzI1MjZjIg_3D_3D_pc
I Was Wondering Why Some Of My Airtable Stuff Not Showing
I'm Trying To See Why All Of Them Is Not Showing ?
Hey @QuietMoneyRadio
Can you please share the workflow URL once in which you have experienced the same so that we can look into it?
QuietMoneyRadio — Reply ·
The Workflow URL you have shared doesn't appear to be correct. Please share the correct Workflow URL.
Kindly select the correct Workflow that you want to enable on Friday.
Have you tried mapping the workflow ID directly in the action step?
No I don’t know how
Please try now by enabling the map button once and then map the workflow ID in the field.
