Airtable
Status: Open · Asked by OlivierFrench on · 0 views
OlivierFrench — Question ·
Hello everyone,
I'm experiencing an issue with my Airtable/Pabbly automation that was working fine until recently.
Issue: Pabbly can no longer detect my view in my Airtable base (the view doesn't appear in the dropdown list when configuring the trigger).
Question: Has anyone encountered this same problem recently? Could an Airtable or Pabbly update be causing this?
Thanks for any feedback or solutions.
Hey @OlivierFrench,
Thanks for reaching out.
The workflow you shared appears to be disabled, which is why it is not triggering. Kindly enable the workflow and then monitor it—it should start working as expected once turned on.
Please let us know if you still face any issues after enabling it.
OlivierFrench — Reply ·
No, that doesn't work either
Hey @OlivierFrench,
Upon further review, it appears that your Airtable connection has expired, which is likely why the workflow is not triggering.
We recommend that you:
  • Reconnect Airtable by creating a new connection
  • Set up the trigger again using this new connection
  • Then monitor the workflow to check if it triggers as expected
Please try this and let us know how it goes.
