Alpha Sender - Twillio SMS
Status: Closed · Asked by Brendan Bunting (#Brendo) on · 0 views
Hi Guys, how do I get the SMS sender in the Twillio connect app to use the Alpha sender number?
Hey @Brendo
As per the API documentation of Twillio, there is no such field that can support the alpha numeric sender number.
You can also check the following API documentation for the same.
So I cant use it with Pabbly at all? What other options do I have? Most local Australian numbers are not SMS compatible.
Hey @Brendo
As we can check from Twillio's API documentation we could find that users can pass the alphabets in the phone number field.
Perhaps you can contact the Twillio support team for the same, they might answer you breilfy.
Thanks Supreme, They have explained the Alpa sender gets attached to a mobile number. Now im off Ill deal the regulation pain trying to get a Mobile number in Australia on Twillio. Hours of fun lol.
