Alphabetize Product Pulldown
vortek
As I am getting more products in it is defaulting to order of addition but am starting to waste time trying to find the product, is there anyway to add a product search to find or at least alphabetize the list? I am wasting a ton of time and causing frustration trying to quickly find a product when it shoudl not be this way.
V
Vipin Mishra
Hello @vortek,
We would like to inform you that you can copy the Plan or Product name which you want to select for your customer and paste in the Select box so that you will get the Product name and Plan name directly so you can assign your customer easily without much manual work.
If you need further support please reach out to us.
Regards,
Vipin Mishra
