An automation GravityForms to SendFox stopped working
Status: Closed · Asked by diegorepetto on · 0 views
diegorepetto — Question ·
Hi
It worked correctly, I see the history and take the data.
Now I test it, it takes the data correctly but it doesn't send it to SendFox.
or I fill out a form in Gravityforms, and it doesn't send it to Sendfox
What can be happening?
Hey @diegorepetto
Seems like you have done some changes in your Gravity form or didn't recapture the webhook response correctly. Because of that, you might not be able to process your workflow. Please recapture the webhook response once and then map the fields.
