Applying Tags
pete
I have created a workflow with a webhook that is working well but the tag application only works on the first contact. I suspect this is a mapping issue but i can't seem to fix it. Do you have any suggestions?
Hey @pete
In the "Infusionsoft by Keap : Apply Tag to Contact" action step you need to map the contact Id from the above action step.
Though we have mapped the correct Contact Id, kindly try the automation in the live version. I hope this might help you out.
