Are webhooks and other triggers down?
Status: Closed · Asked by Shane Harris on · 0 views
Hey Everyone - are triggers down? I am trying to work on multiple workflows and cannot get any info to land to trigger (Clickup, Jotform webhook - nothing is landing on Pabbly's end)
Hey @shane6836
Sorry to hear that can you please share the workflow URL with us once you have tried the same? Also, let us know while configuring the webhook URL are getting stuck at any step.
(You can watch the following videos' last part to set the webhook URL)
Hi @Supreme- URL is https://connect.pabbly.com/workflow/mapping/IjU3NjUwNTY4MDYzNTA0MzE1MjY0NTUzNjUxMzMi_pc
I have reset the webhook at every point i can with no luck - has been working fine until this afternoon when i am trying to make some changes
Can you please try again by reconnecting the action step once you can avoid passing pc_skip_field in the Folder and List name?
Hey!
So, i tried making those fields blank (no change) - then I mapped to teh actual folder and list i was using to trigger and it worked. Tried again with nothing and it worked, and then added back in the pc_skip_field and its wokring again?
OK, please monitor your workflow for a while and let us know if the issue still persists.
