Array Help
Status: Closed · Asked by miike on · 0 views
Hi Guys,
Re Workflow
Name: TEST - CLEAN DONE
URL: https://connect.pabbly.com/workflow/mapping/IjM2NzAxMyI_3D
I am using a webhook trigger which receives an array of URL file locations.
See here:
https://share.getcloudapp.com/P8u1AQ0R
I now want to add all the file locations in the array into an Airtable attachment field.
This needs to work no matter how many file locations are in the array, such as 10 or 200.
See here:
https://share.getcloudapp.com/JruOrojY
Please help on how to make this work?
Thanks heaps!
Hey @mike
Kindly capture the webhook response in advance response by toggling the "Simple Response" button and then you can use the Line Itemzier action step in your workflow to Insert Image in comma separately.
You can also refer to the following tutorial video on Line Itemzier action for your basic understanding. Kindly try it in a similar fashion and let us know if that works for you.
