Article not big enough
Status: Closed · Asked by Erwin Verbeek on · 0 views
urban101 — Question ·
I used the tutorial on YouTube:
youtube.com/watch?v=cDkha_bHpXg
to create a workflow for writing articles based on blog titles.
The only thing is that articles are not bigger then a few sentences and I want at least 300 words articles with a title and subtitle written in Dutch.
Does someone have the fix for me?
urban101 — Reply ·
Changing the prompt in English didn't help eather. The prompt is: Write a dutch article of at least 300 words with subtitles.
Hey @urban101
The Open AI's API generates text based on the given prompts, but the exact length and structure of the output may vary.
To generate longer articles, you can experiment with providing more detailed prompts, asking open-ended questions, or providing additional context conditions for the Open AI to work with. However, please note that even with these techniques, the output may not always precisely meet your desired length.
So, kindly same first in Open AI's dashboard and then pass the prompt according to it in the workflow.
urban101 — Reply ·
There must be a way to get longer articles right? It seems to be that it only writes introductions. No Title, no subtitles and no more than 150 words. Is there somebody who got this issue and solved it with a prompt or another solution?
Hey @urban101
You can try the same on the Open AI itself first to get your desired content.
Here is an example that we have tried related to your prompt.
urban101 — Reply ·
Yes I understand I can get it in OpenAI itself, but I want this to be automated with Pabbly. Based on the blogtitles in the Google sheet to be written automatically.
Then kindly pass the same prompt in the Open AI action step to get the result.
