Asana follower not mapable
Status: Closed · Asked by oroettger on · 0 views
oroettger — Question ·
https://connect.pabbly.com/workflow/mapping/IjQ1MDE1NSI_3D
when I create a new task in asana or update a task in asana it is not possible to map followers. I tried it with names, the number in asana and the emailadress of an follower. Am I doing mistakes or is there something wrong in pabbly or asana?
Hey @oroettger
For your concern, we would suggest you to use the "Get User" action step to retrive the additional details including the Id of the follower which you can further pass to the Follower field further.
oroettger — Reply ·
Hey @Supreme ,
that does not work either. By the way, I do have already the GID of the users. But when entered in the users field unsing map, it does not work.
Hey @oroettger
You can only pass one follower Id in the Follower field of the Asana action step.
Kindly pass only one follower in the field without a comma and then try again.
oroettger — Reply ·
but i need more. how could i rsolve that ? it is possible in zapier:
and when not mapped, but choosen in pabbly, it is possible to choose more than one follower.
Hey @oroettger
Kindly allow us some time, we are currently looking into it.
Shall notify you shortly.
Hey @oroettger
We have made some changes in the action event, kindly give it a try by passing multiple followers in commas separately.
E.g. -
["fhiudfihds","fgdf"]
oroettger — Reply ·
Hey @oroettger
E.g. -
Hi, I was on Holiday. Thanks, I will try.
oroettger — Reply ·
Hey @oroettger
E.g. -
Thank you, it is working. But i have a problem with https://connect.pabbly.com/workflow/mapping/IjU3NjAwNTY4MDYzNjA0MzU1MjZhNTUzNCI_3D_pc
also related with asana. The last step creating a task in Asana ist not working and i do not know why. it is the second route (Route Ausschuss gefunden) the last step.
Error Message: Could not parse request data, invalid JSON
PabblyMember4 — Reply ·
Hey @oroettger
We have checked the workflow and found that you are not entering the tags in the correct format. Could you please re-check and pass the tags in the correct format as shown in the help tip in the workflow.
Kunal
oroettger — Reply ·
Hey, thanks, but I did this also, but did not work. I can try again, but just to mention, the tag you are seeing is from the drop down list offered by pabbly in this field. This should work as well, or?
oroettger — Reply ·
the error occurs, if i map content from the first step in the notes field. the workaround is, to enter the notes with another step "updating task in asana".
But normally it should work with one step. anyway, perhaps you could have a look.
Pabbly13 — Reply ·
Hey @oroettger !
We can see in the both Asana step in your router 2, the response is correct, it seems the issue was resolved at your end-
Kindly do a tets submission and check if this is working for you in the automation now.
Hope, to hear from you soon.
