Assistant needed for Chatgpt and messenger automation.?
Status: Open · Asked by Arun Gayswal on · 0 views
Arun Gayswal — Question ·
Hi team,
I'm facing an issue with the integration of ChatGPT and Messenger automation in Pabbly Connect. Although I’ve upgraded my ChatGPT account, Pabbly Connect is still showing that it's not upgraded, and the automation isn't working as expected.
Here's what's happening:
  • I’ve set up the workflow to automate responses on Facebook Messenger using ChatGPT.
  • Even though I upgraded my ChatGPT, the system is saying it's not upgraded, and the connection isn’t triggering properly.
Could anyone assist with this issue or let me know if there's something specific I need to adjust? Any help would be appreciated!
Thanks!
Arun Kumar
Hello @sonuku
Please try setting up the connection again. If the issue persists, we recommend contacting the OpenAI team, as the response is being received from their end.
Arun Gayswal — Reply ·
I try again and again . My gpt working already fine.
Please tell me why its not working . its saying The model `gpt-4o` does not exist or you do not have access to it..??
MArko — Reply ·
I have the same problem integrating chatGPT. It works fine with Gemini for my autoreply bot, but I intended to use chatGPT which I am paying for. Please tell me how to resolve
