Auto-generated funnels and websites in GoHighLevel a.k.a LeadConnector V2
Status: Open · Asked by SmartMarketing on · 0 views
I'm curious if anyone has created something like the following for creating auto-generated funnels and websites in GoHighLevel a.k.a LeadConnector V2.
I've built conversion-focused page templates using custom variables for everything (logos / images, background colours, all text elements, etc).
I have created forms for the client to submit info about their business that will populate the custom values on the page.
These are aligned with the custom fields on the forms. What I want to do is take things to a whole another level using Pabbly to build automations that:
- Take form submissions
- Pass data through templated AI prompts (OpenAi or Claude)
- Generate sales copy based on best practice frameworks
- Populate High Level variables
If anyone has done this before and has ideas to make this as awesome as possible I'd love to hear them.
If you want to work with me to build the automations in Pabbly, I'd be happy to share my snapshot with page templates, forms, etc. I've spent easily 40+ hours on building these templates so it would save you a lot of time if you are interested in a system like this for your agency.
Hello @SmartMarketing,
You can refer to the following tutorial as it seems to align with your use case -
youtube.com/watch v=-IKo9JtvPbw
.Can you please elaborate a bit more about what you are looking to achieve by the below
Hello @SmartMarketing,You can refer to the following tutorial as it seems to align with your use case -
youtube.com/watch?v=-IKo9JtvPbw
.Can you please elaborate a bit more about what you are looking to achieve by the below?
What I meant is to take the information submitted by the client in the High Level form, then pass it through to either Claude or Open Ai which has prompts to take the info and write sales copy with it based on certain frameworks.
From there, the copy that is generated is entered into another form which then populates the custom variable on the High Level page.
You can use the 'Form Submitted' trigger step to capture form submissions, followed by the 'ChatGPT' action step to write sales copy.
There is no action event that can help you transfer the copy into another form, and we are not sure what you mean by 'populating custom variables in High Level Page'. Please check the available action events in LeadConnector to see if any of them suit your use case.
You can use the 'Form Submitted' trigger step to capture form submissions, followed by the 'ChatGPT' action step to write sales copy.There is no action event that can help you transfer the copy into another form, and we are not sure what you mean by 'populating custom variables in High Level Page'. Please check the available action events in LeadConnector to see if any of them suit your use case.
Thanks for the info.
Populating custom variables in High Level can be done by filling out a form as the custom fields of the form can align to the custom variables on the page.
I'll just have to figure out a way to take the Ai's output and get it entered into another form.
Are you looking to execute this endpoint?
https://highlevel.stoplight.io/docs/integrations/2c0dba6197bcb-upload-files-to-custom-fields
