Auto Google Review 404 Not Found
Status: Closed · Asked by Vince Pham on · 0 views
I got the problem with auto review got 404 error not found when test auto writing the reply Google even though I map the correct name field from review.This function used to work but it does not work anymore. Please help with it. Thank you very much.
Hey @macmarketing
Could you please share the workflow name to check the issue?
Kunal
Sure,
The workflow name is 76180 Venue Spa & Nail Review
Please help check it ASAP
Ted
Hey @macmarketing !
We have updated the workflow for you and the step is now working-
You can continue to work on it further.
