Automation Issue
Status: Closed · Asked by Dr Sajjan Academy on · 0 views
Group Names:
[TABLE]
[TR]
[TD]#01 ECG - Concepts... (4)[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]#02 ECG Skill Mastery (4)[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]#03 Advanced ECG ... (4)[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]#04 50 ECG Challenge (4)[/TD]
[TD][/TD]
[/TR]
[/TABLE]
We have made automation that whenever the customer purchases our course. it will create an order in Woo Commerce and then they will enroll for the course in Graphy. But the issue is No customer is enrolling for the course in Graphy even though the order is created in Woo Commerce. Please check the issue.
Hey @Dr Sajjan Academy
Kindly cross the check the history logs of your respective workflow(s) and let us know in which execution your workflow didn't process.
In history we find this error sir
Kindly try authenticating the Graphy action step in your workflow once and then try again. Seems like you have passed the SubDomian incorrectly.
Okay will try and get back sir
Thank you, we got the solution
