Automation works but shows error.why ?
Status: Closed · Asked by max4321 on · 0 views
max4321 — Question ·
Task History ID: IjU3NjcwNTY0MDYzNTA0MzY1MjZmNTUzYyI_3D_pc
Hello, I have a question regarding information about errors in automation. Automation is designed to insert posts on Pinterest. One or two posts are posted daily. I did notice, however, that automation reports errors, which is strange because automation works. The error is reported by the Pinterest module, although it does its job. What is the reason for this?
Hey @max4321
It seems like the Media URL you passed in the Pinterest action step was now not coming from your triggering application and because of that your Pinterest action step isn't getting any media to upload as a result it is showing an error.
