Basecamp comment on a To-Do
Status: Open · Asked by Matt.Dorzok on · 0 views
I don’t see the option to comment on an existing to-do in basecamp. Is this possible?
I’m a longtime Zapier user and would like to try pabbly but it seems to be missing this option
If you want this action event to be added to the Basecamp application in Pabbly Connect, you can submit your request on our dedicated platform:
https://roadmap.pabbly.com/b/Update-Existing-Application
Our integrations team will review your request and, if feasible, add the desired action event to Pabbly Connect.
I don’t see the option to comment on an existing to-do in basecamp. Is this possibleI’m a longtime Zapier user and would like to try pabbly but it seems to be missing this option
Hello @Matt.Dorzok ,
If you want it on immediate bases. You can dm me I'll help you out. FYI I'm not from pabbly connect team I'm an automation freelancer who helps other pabbly users.
