Big Commerce errors when connecting to Deskera
Status: Closed · Asked by showell on · 0 views
showell — Question ·
Good Afternoon Pabbly Family,
Im having some issues in linking my BigCommerce account to Deskera to create invoices. Here are the errors Im receiving:
1) Failed due to exception while processing the request. Error Message: JSON parse error: Unrecognized character escape (CTRL-CHAR, code 10); nested exception is com.fasterxml.jackson.core.JsonParseException: Unrecognized character escape (CTRL-CHAR, code 10)
2)JSON parse error: Unrecognized character escape (CTRL-CHAR, code 10); nested exception is com.fasterxml.jackson.core.JsonParseException: Unrecognized character escape (CTRL-CHAR, code 10
Any help would be greatly appreciated.
Thanks!
Pabbly — Reply ·
@showell
Looks like you have not mapped some field with correct values. Please make sure to read the help text once and map them correctly.
Here's the screenshot showing the same -
showell — Reply ·
@showell
I have made the adjustments and added the codes using the tips but still receiving the same error, is there a way i can pinpoint where the issue is?
