Bigship.in & Bizanalyst is not in pabbly connect, how to connect bigship & Bizanalyst with whatsapp api?
Status: Open · Asked by sanket.rareprint on · 0 views
sanket.rareprint — Question ·
Hi @sanket.rareprint,
Currently, we don't have a direct integration with Bigship.in and the Bizanalyst application. If you would like to see these applications added to Pabbly Connect, you can submit your request on our dedicated platform: https://pabbly.featureos.app/b/Integration-Request
Our integrations team will review your request, and if possible, add the desired applications to Pabbly Connect.
In the meantime, if these applications support webhooks or have a REST API, you can try using Webhook by Pabbly or API by Pabbly to achieve your use case.
youtube.com/watch?v=FRkl5R7-Ls0
youtube.com/watch?v=bmf4och_kTk
