Blog ID is not shown even after connecting through Blogger. Please FIX it ASAP. Or Give instruction to map it manually
Status: Closed · Asked by khelcorner on · 0 views
Your Workflow URL: https://connect.pabbly.com/workflow/share/CUEHNVIFUjFeFAVoDlkCJV9LAQVXDlMxUUhURlBfVi5VG1YDVhcNZ1wQVXdVBgBhAElXPQJeBD8PG1VRBlAHdAMZAAUGGV0AVWZUEQJdXHYJaw##
Task History ID: Not Found
Hey @khelcorner
As we can see that the name of the blogs is showing now. Please make sure that you have made the correct connection with the correct Blogger account.
Gone Now. and also at that time not url were shown
It is very fraustating. I was about to buy premium but it sucks. sorry to say
Can you please check your connection once from your workflow once and then try.
