Box (not Dropbox) integration
Status: Closed · Asked by mhassan on · 0 views
mhassan — Question ·
My company is moving from Google Drive to Box drive (not Dropbox). Does Pabbly connect have any integration with Box folders?I would prefer not to mess with Box APIs to make this working.
Hey @mhassan
As of now, Box's intergation is not available on the platform but you can post the request to add the integration here - https://pabbly.hellonext.co/
Our integration team will look into it and can guide you accordingly.
mhassan — Reply ·
Is there a way to automate copying google Docs (from google drive) to the Box directory?
Currently, Box API is not integrated into the platform. Further, if Box API provides the action step to create/upload a file then perhaps your use case is possible.
