Brevo connection issue
Hi, i am trying to connect brevo to contact form 7 and i only get errors, i tried google sheets but the same errors, i tried webhook by pabbly nothing changed, and i tried contact 7 webhook the same errors. If anyone Faced these errors please share the solution. Sometimes the error is invalid parameter, sometimes invalid phone number and sometimes 241 or so errors
Active member
Hello @myQustoforum
We recommend you follow this tutorial in order to set up a workflow(if it matches your requirements) -
Also, please provide us with the use case you are trying to achieve so we can assist you accordingly.
