Brilliant Directories trigger for Custom Forms?
Status: Open · Asked by SuzanneBH on · 0 views
Is there not a trigger available for Custom Forms in Brilliant Directories? Can one be added?
Hi @SuzanneBH,
Currently, we don't have a trigger for Brilliant Directories Custom Forms. If you wish to see the trigger event added to Pabbly Connect, you can place a request on our dedicated platform at: https://pabbly.hellonext.co/.
In the meantime, you can try using Webhook by Pabbly to achieve your use case.
