Build multiple triggers with same webhook URL
Status: Closed · Asked by shuvo-myalice on · 0 views
shuvo-myalice — Question ·
Hi I am building multiple triggers with Webhook setup by instructions option. Can I have the same webhook URL for multiple triggers for one account?
Hey @shuvo-myalice
Do you want to use a single webhook URL in all your workflows? If, yes then it is not possible since every workflow's trigger event contains a unique webhook URL.
Further, if you want to process the same webhook response in multiple ways separately with a single webhook URL then we would recommend you use the Router action step.
ghalitzka — Reply ·
Hi, I'm not sure if this is the same question shuvo-myalice was asking or not...
I'm wondering if it's possible to have multiple triggers for the same workflow. Suppose I have three different Google Sheets that are functionally identical and will send the same data in the same format via the webhooks. Is it possible for a triggering action in any of the three sheets to activate the same workflow? Or do I need to set up a separate workflow for each of the three sheets?
Thanks for your help!
Hey @ghalitzka
Regarding your concern, you can configure the same webhook URL of your trigger event in your different Google Sheets.
ghalitzka — Reply ·
Okay, thanks for your reply! Can I simply paste the same webhook into the Pabbly Connect extension in multiple Google Sheets and use the same Workflow? Or will I need to clone the Workflow? It didn't seem to work when I pasted the same webhook using the same Workflow with multiple sheets, but I may not have done it properly. Thank you!
ghalitzka — Reply ·
I answered my own question! I figured out what I did wrong, and was able to apply the same webhook to multiple spreadsheets, so an entry in any of the sheets would act as a trigger for the same Workflow.
However, now have another question that's somewhat related to the first. I would like to apply a different Workflow to one of the spreadsheets. However, it appears there's no way to trigger a second Workflow from an entry in another column of the sheet. (Say that the first workflow is triggered by an entry in Column G, but I would like the second Workflow to be triggered by an entry in column C.) Is there a way to apply multiple Workflows to the same Google Sheet?
Setting multiple webhook URLs in a Google Sheet is not possible.
