Calendly to amoCRM - Custom fields
Status: Closed · Asked by Harpreet on · 0 views
Hi there,
Ttrying to transfer data from Calendly (Invitee created event type) into custom fields of amoCRM.
Is this supported?
The steps workflow is in the attached screenshot. The first step is not visible on the screenshot - it was Calendly: Invitee Created.
Best regards,
Harpreet
Hey @Harpreet
Currently, we cannot support the custom fields in the amoCRM's action events due to some limitations on the API.
