Calendly will not connect
Status: Closed · Asked by Zuri White on · 0 views
I can not create a work flow with Calendly. It is stuck on waiting for response. I created the test appointment and went through all the steps on the videos. But it gets stuck here. I see someone else had this same issues and the resolution was never posted. I signed up with google. I tried to do it over and over always the same thing. Stuck for hours. Note. Please help.
Hi @Serious Credit,
Please disable this current workflow and set up a new workflow from scratch (without cloning). Make sure you log in to your Pabbly Connect and Calendly accounts in an Incognito tab, establish a new connection, and then make a test appointment.
Attaching a video for your reference
