Campaigns are not visible in pabbly connect
Status: Closed · Asked by shreeshchandra.mishra@ats on · 0 views
When I tried to send data from pabbly to HubSpot CRM some of the campaigns is not visible in the options section.
I've created different campaigns for the different websites but it's not visible within the above option.
Hey @shreeshchandra.mishra@ats
Kindly share the name of the workflow in which you are using the desired action step.
The campaign field only fetch the campaigns which are already available on your HubSpot account. Since there is no list limit from our end.
Kindly check again from your account and then try again.
