Can i connect Suite CRM (open Source ) through pabbly connect
Status: Closed · Asked by Rekha babulkar on · 0 views
Rekha babulkar — Question ·
i have downloaded Suite CRM open source, and i want to integrate this to pabbly - how can i do that ?
Hi @Rekha Babulkar,
Currently, we don't have a direct integration with the application you are referring to. If you would like the SuiteCRM application to be added to Pabbly Connect, you can submit your request on our dedicated platform:
https://pabbly.featureos.app/b/Integration-Request
Our integration team will review your request and, if possible, add the desired application to Pabbly Connect.
In the meantime, if SuiteCRM supports webhooks and you want to set up SuiteCRM as your trigger step (the first step of the workflow), you can try using Webhook by Pabbly to connect with the application.
youtube.com/watch?v=FRkl5R7-Ls0
If you want to set up SuiteCRM as an action step and it has a REST API, you can try using the API (Pabbly) module to execute the endpoint you need.
youtube.com/watch?v=xYC5mTobFfc
