Can you manually amend some info in a flow and re-execute?
Status: Closed · Asked by RoCrow on · 0 views
RoCrow — Question ·
Often I have a partial fail because someone mistyped their email. Is there a way to manually edit the submitted data in a field in a partially failed flow, then reexecute the failed steps only? Would be a great timesaver!
Hello @RoCrow,
Yes, you can edit the details while re-executing the workflow, refer to the attached image for better understanding.
RoCrow — Reply ·
Aha, I didn't know that was an option after choosing to re-execute. Thanks!
Hello @RoCrow,
Yeah, there is that option. Glad I could help.
