Cant add custom Parameters and values to freedcamp Actions.
Status: Closed · Asked by jvaldez on · 0 views
So im trying to make a workflow where a status of a task is updated from "in progress" to "Completed"... But the option its not available in the Freedcamp section, i tried to see if i can add custom parameters and stuff, but that option is disabled. I think thats an option that should be enabled for all apps.
1- Please enable the custom parameter option for all apps.
2- Add "Task Status" to the default parameters in "Update Task" on freedcamp.
3- Would be nice to also have some basic triggers, right now there no triggers.
Meanwhile im going to use the API Action to send the Task Status update request to freedcamp. Thanks.
Hey @jvaldez
You can post the request to add the custom fields in your desired API's action step and can upvote it here - https://pabbly.hellonext.co/b/Update-Existing-Application
Our integration team will look into it.
Thanks!
