Capture USSD command within Pabbly automation workflow
Status: Closed · Asked by Moussa Djibrina on · 0 views
Hi Pabbly,
One of the most interesting automation i am searching for now is to capture USSD Command and process it through a pabbly workflow. Forget the response way as it is not a problem and I can send back responses via SMS or Whatsapp. The command(USSD prompt like 123#1) must be captured as normally as it comes via "Email Parser by Pabbly". Please do not go through the Webhook solution as webhooks are not common here.
In fact I contract softwares with NGOs and Microfinance and those structures require "no internet" field based communication. I use SMS syntaxes to perform some useful actions but USSD seems to do better as it does not remain on the phone once sent.
How can Pabbly help me to get this VERY IMPORTANT Future?
Best regards,
Moussa Djibrina
Hey @Advent1.paysah
Can you record a short video on your use case once, since it's not clear how you want to process the data from the webhook?
Hey @Advent1.paysahCan you record a short video on your use case once, since it's not clear how you want to process the data from the webhook?
I thank you for your response in which i find a way to complete my question: in fact, not only the ussd command must be captured but also the phone number from which this ussd command originates. To respond to you let me add that my issue is not to process the data further, because i will have just to pass this captured data through another application (within pabbly connect) and then i will be able to reply to the customer. The main issue for which i am asking help is the capability to capture the USSD command including the originated phone number! And if possible, Webhook is not needed as an option because as i explained, Webhook is not common in my business environment. A tool like Email Parser will be more useful.
Regards,
Can you please record a short video on how you can capture the data on Pabbly Connect and from which application?
