Character encoding problem for scandinavian with Gmail
Status: Closed · Asked by evohealth on · 0 views
evohealth — Question ·
Hi! I'm a new user testing Pabbly hoping to migrate from Zapier.
I ran into a problem with Pabbly sending emails with Gmail.
I the email subject I cant write scandinavian letters Å, Ä, Ö (A with a ring, A with two dots and O with two dots) Å, Ä, Ö
HTML Å Ä Ö
(Html dosen't work in titles, just added it so you can see the caracters correctly)
Pabbly — Reply ·
HTML Å Ä Ö
Here's the workaround for the same. Please check it - https://forum.pabbly.com/threads/gmail-translate-general-language-characters.179/
evohealth — Reply ·
Thank you for your fast response! It seems that the builder has been slightly updated since that post. I got it working but more step by step instructions and an explanation of what it does would help.
As I understand it this transformer changes insert data to UTF-8?
The name entered would be the Recipient Name (it only says name)
The above worked
At first the Search & map didn't show the transformer but I could find it by searching =. I could replicate this when creating a new Data transformer
