ChatFlow passing variable string names instead of Values
categoryx
I have a very basic whatsapp flow set up the takes a keyword to initialise a question and take a parameter, I am then sending this and the stored mobilenumber to pabbly connect (because these are in as default variables I am assuming that one is already populated on chat) the issue is that instead of receiving value of these contact field variables it is actually sending the variable number so $CompanyNumber is populated from the question and then $MobileNumber I am assuming is store, even if I was wrong on that $CompanyNumber is also coming through as text saying $CompanyNumber and not for example 12345678
https://share.zight.com/BlumlKeQ
