Chatgpt is not connecting and the api key is not showing activity
Status: Open · Asked by Aggierob07 on · 0 views
1. Error Message: “The model GPT-4 does not exist” suggests:
• The requested model (GPT-4) is either misspelled, unsupported, or not available under your OpenAI subscription.
• Alternatively, the API request is not reaching OpenAI properly.
2. No Activity on OpenAI Dashboard:
• This indicates that Pabbly is not sending the request to OpenAI.
• The issue likely lies in Pabbly’s configuration or how the request is being constructed and sent.
3. Errors Across All Fields:
• This points to a systemic issue in Pabbly’s integration with OpenAI, rather than an isolated field-specific error.
Hello @Aggierob07 ,
it's working fine for me please refer below screenshot for reference
Hello @Aggierob07,
Kindly provide us with the workflow URL where you're encountering these issues so we can review it and assist you more effectively.
Hello @Aggierob07 ,
thank you my friend
Hello @Aggierob07,Kindly provide us with the workflow URL where you're encountering these issues so we can review it and assist you more effectively.
The error message you're seeing is from OpenAI. It appears that you either don't have the required plan to access GPT-4, or you lack sufficient credits. Please contact OpenAI's support team for further clarification on the issue.
https://community.openai.com/t/openai-error-invalidrequesterror-the-model-gpt-4-does-not-exist-or-you-do-not-have-access-to-it/376230/3
