ChatGPT -> Wordpress "Invalid JSON body passed."
Status: Open · Asked by yarrak on · 0 views
yarrak — Question ·
Task History ID: IjU3NjUwNTZmMDYzZjA0MzM1MjZmNTUzNTUxM2E1MTYwNTQzMDBmMzUi_pc
I'm getting the following error on some of my posts for some reason. I have a 'replace' filter before this to replace " with '. I've added the task history ID for reference. Thank you
Hi @yarrak,
The data you are passing in the Excerpt field seems to contain a double quote, which appears to be causing the error. Please add another Text Formatter to your workflow to replace the double quotes in the data passed in Excerpt as well.
yarrak — Reply ·
Hi, i set a formatter again and i still get the same issue sometimes. Here is the task id: IjU3NjUwNTZlMDYzNjA0M2Q1MjZkNTUzMTUxM2E1MTYyNTQzMTBmMzMi_pc
It seems that you made some changes to your workflow after the task in which you encountered the error was executed. Because of this, we are unable to determine the exact cause of the error. Kindly monitor your workflow for some time, and if you encounter the issue again, let us know without making any further changes to the workflow.
