Click funnels
Status: Closed · Asked by 平城寿 on · 0 views
Hisashi — Question ·
I have 2 order forms in one funnels in Click Funnels.
However, there is only one Wehook setting per funnel.
In this case, how can I separate the webhooks for two different forms?
Hey @Hisashi
You can try the "Router" action step in your workflow where you can individually establish the condition for your order forms separately to process your orders.
For a better understanding of the Router action step, you can check out the following video tutorial -
Hisashi — Reply ·
Thank you so much!
