Clickup task add comment error OAUTH_027
Status: Closed · Asked by patrickdoodlehog on · 0 views
patrickdoodlehog — Question ·
I tried setting up a trigger to comment on clickup tasks already created however Im getting this error:
Thanks for the assistance guys!
Pabbly — Reply ·
Which trigger event you're using in ClickUp? Also please share the workflow name as well for reference.
patrickdoodlehog — Reply ·
it is the create task comment trigger:
Hey @patrickdoodlehog
We have checked your workflows and we couldn't find the Trigger with ClickUp with "Update Task". But we did find the Clickup Action in you "Shopify To Google Sheets", where you have mapped the time without timestamp format and the tags which you were passing were not in double-quotes.
Furthermore, we have done the changes to your workflow. So now please give it a try and let us know if that works for you.
Previously -
Now -
I deleted the update task trigger as its causing the auth error let me add it again thanks!
I loaded it again its called
ClickUp : Create a Task Comment
Please map the task_id or the task name properly. Then only the action will respond accordingly.
