clickup + vbout automatic tags help
Status: Closed · Asked by nor on · 0 views
I have two questions regarding this issue.
I want that when the status in ClickUp is the same in vbout tags. For example, if I want to change the status from Warm to Hot. I then wish to vbout that if it already has the Warm tag, remove it and add the Hot tag
The second question is a little bit of the same. When ClickUp status changes I want that tag to be in that contact that was added before.
Please help
Hey @nor
Kindly share the workflow with us, so that we can look into your use case and can guide you accordingly.
The use case you are asking for and the workflow you shared don't resemble, so can you please elaborate on your use case once?
