Cloning workflow issue
Status: Closed · Asked by Troy Coker on · 0 views
troycoker08 — Question ·
Have I missed something? What is the point of having the ability to clone a workflow but be restricted with replacing the Trigger. I'm using a web hook trigger and have built a complex workflow that I do not wish to manually build every time. When I clone the workflow and try to add a different trigger (i.e. delete previous trigger and add new web hook end point and then rename) I'm unable to. Maybe I'm not looking in the right place. Can anyone advise please.
troycoker08 — Reply ·
Seems I did miss something. Click on Choose App again and new end point is generated. Trial and error. Apologies.
Neeraj Agarwal — Reply ·
Glad it is all sorted for you. Thanks
